pixely- death or hot pixels
Autor: ¨StanLeo
16. Listopad 2013, 13:47:53
Zajímá mě jak je to s mrtvými a horkými pixely...
Na netu jsem narazil na tento problém,kt. se týká hlavně při focení astrofotografii,focení s dlouhým časem...
Nedalo mi to a zkusil jsem si otestovat svuj fotak...a něco se našlo,ovšem otázka jest,zda je to normální anebo problém?
Jinak podobný test dle http://www.grosman.cz/2008/10/25/premapovani-senzoru/
Díky předem za váš čas a názory.
http://ulozto.cz/soubory/stanleo/documents/test-dhp/
I onceCoach Outlet Onlinefor
I onceCoach Outlet Onlinefor success because we do notCoach Factory Outletlisten. Challenge yourself to Coach Outletlisten more than asked the DirectorCoach Outlet Onlineof MarketingProfs.com what she thoughtCoach Outlet Storemade her Twitter handle so popular;Coach Outlet Store Onlinefor someone who isn’t famous,Coach Outlether following is impressive. Here’sCoach Factory Onlinethe conversation @BigRyanPark To Coach Factory Outletalways try and respond, and to listenCoach Outletmore than you talk. That’s goodCoach Factory Outletadvice for life, actually. Not Coach Outletjust Twitter.— Ann Handley Coach Outlet Store(@MarketingProfs) November 12, 2013Coach Outlet Store OnlineBuild On The Fact That You HaveCoach Outlet OnlineEnough.Let’s connect the dots. True Religion JeansLearning the art of contentment canTrue Religion Outlet lead to lower stress levels; lower True Religionstress levels leads to higher brainMichael Kors Outlet Onlinefunctionality; it is more likely thatMichael Handbags Outlet you are successful when you are Michael Kors Outlet Store Onlinethinking straight. If you build onMichael Kors Outlet Stores the fact that you have enough and Chanel Outlet Onlinelearn the art of contentment, youLouis Vuitton Outlet will go places (and people will Louis Vuitton Handbagsfollow).
