Rada pri fotení
Autor: BedlekM
22. Únor 2013, 21:53:31
Ahojte, mám Nikon d5100 a neviem s tým ešte dobre robiť. Minule som bol na lyžovačke fotil som ako skáču a tak ale bolo to dosť rozmazane teraz pôjdem znova a chcem aby sa mi už fotky vydarili.. Prosím poradili by ste mi na akom režime by som dobre zachytil ako niekto skače na skoku?
I onceCoach Outlet Onlinefor
I onceCoach Outlet Onlinefor success because we do notCoach Factory Outletlisten. Challenge yourself to Coach Outletlisten more than asked the DirectorCoach Outlet Onlineof MarketingProfs.com what she thoughtCoach Outlet Storemade her Twitter handle so popular;Coach Outlet Store Onlinefor someone who isn’t famous,Coach Outlether following is impressive. Here’sCoach Factory Onlinethe conversation @BigRyanPark To Coach Factory Outletalways try and respond, and to listenCoach Outletmore than you talk. That’s goodCoach Factory Outletadvice for life, actually. Not Coach Outletjust Twitter.— Ann Handley Coach Outlet Store(@MarketingProfs) November 12, 2013Coach Outlet Store OnlineBuild On The Fact That You HaveCoach Outlet OnlineEnough.Let’s connect the dots. True Religion JeansLearning the art of contentment canTrue Religion Outlet lead to lower stress levels; lower True Religionstress levels leads to higher brainMichael Kors Outlet Onlinefunctionality; it is more likely thatMichael Handbags Outlet you are successful when you are Michael Kors Outlet Store Onlinethinking straight. If you build onMichael Kors Outlet Stores the fact that you have enough and Chanel Outlet Onlinelearn the art of contentment, youLouis Vuitton Outlet will go places (and people will Louis Vuitton Handbagsfollow).
Režim ostření AF-C středový
Režim ostření AF-C středový ostřící bod, volič S (Priorita času) nastavit na 1/1000, zapnout Auto-ISO. Pak už je to o zručnosti. Jinak jsou samozřejmě i jiné možnosti. Ještě na sněhu bude pravděpodobně potřeba nastavit korekci expozice na zhruba +1. Chce to vyzkoušet.
Rada pri fotení
OK, ďakujem . Budem skúšať
Rada pri fotení
.... a prepnúť na seriové snímanie
vv
Ahoj,ja fotim plochou dráhu a jak piše kolega nastavím menší čas ale jdu s ostřením na objekt směrem jeho pohybu který fotím a rychlospouští udělam v místech pohybu objektu zmačknu spoušt.
focení nimrodů
Tak co ta slečna, jak dopadla s focením těch nimrodů?
focení nimrodů
