Nik Software po updatu s analog
Autor: jadro
14. Listopad 2013, 14:50:15
Po updatu Nik Softwaru mi ta aplikace zmizela z PS, po procteni rad na forech jsem nainstaloval trial verzi a Nik se v PS zas objevil. Nicmene aplikace po ukonceni uprav fotky spadla i celym PS. Nainstaloval jsem znovu verzi z puvodniho linku v emailu po zakoupeni aplikace. Pmohlo to castecne, Viveza funguje, ale silver efex stale pada.
Nějaké zkušenosti?
I onceCoach Outlet Onlinefor
I onceCoach Outlet Onlinefor success because we do notCoach Factory Outletlisten. Challenge yourself to Coach Outletlisten more than asked the DirectorCoach Outlet Onlineof MarketingProfs.com what she thoughtCoach Outlet Storemade her Twitter handle so popular;Coach Outlet Store Onlinefor someone who isn’t famous,Coach Outlether following is impressive. Here’sCoach Factory Onlinethe conversation @BigRyanPark To Coach Factory Outletalways try and respond, and to listenCoach Outletmore than you talk. That’s goodCoach Factory Outletadvice for life, actually. Not Coach Outletjust Twitter.— Ann Handley Coach Outlet Store(@MarketingProfs) November 12, 2013Coach Outlet Store OnlineBuild On The Fact That You HaveCoach Outlet OnlineEnough.Let’s connect the dots. True Religion JeansLearning the art of contentment canTrue Religion Outlet lead to lower stress levels; lower True Religionstress levels leads to higher brainMichael Kors Outlet Onlinefunctionality; it is more likely thatMichael Handbags Outlet you are successful when you are Michael Kors Outlet Store Onlinethinking straight. If you build onMichael Kors Outlet Stores the fact that you have enough and Chanel Outlet Onlinelearn the art of contentment, youLouis Vuitton Outlet will go places (and people will Louis Vuitton Handbagsfollow).
Mně Silver Efex taky
Mně Silver Efex taky pravidelně padá, kór když v PS dělám déle a mám u fotky více vrstev. Buď zatuhne celý PS či se udělá nová vrstva, ale neaplikuje se na ni úprava ze Silver Efex. Ale u mne to bude asi nedostatečným HW a SW, mám jen 3GB RAM a Win XP.
